brettgavin's avatar
May 07, 2013
How to determine original drive order?
Hi,
I have a Pro4. The drives were removed to be transferred to a Pro6. THe person who removed them to give them to me didn't record the original order. I put the drives back in the 4 and booted it up. No dice. switched the order around a couple times without any luck. Does anyone know how I can determine the original order without (1) losing my data, and (2) without swapping drives around 24 times?
Thanks in advance!
  • Explain 'no dice'. Does it just sit at 'Booting...' on the LCD screen?
    If the array was healthy when it left the old host, it should boot fine, no matter the order.
    Booting it in Tech Support mode, support agents can quickly check what the original boot order was.
  • Sorry, that was pretty vague.
    I meant, it boots, but in Frontview, not much works. Volume Settings... .... ..... nevermind.
    As I was writing this, I realized I'm on windows 8 and have IE 10. Everything works fine in FF. The shares weren't available immediately when I booted it up yesterday, but they are here this morning! :)
    Sorry to be a nuisance with a browser issue...
    Have a good one!
  • Glad to hear its back. Yes, a pain it doesn't work across browsers properly, evil JavaScript thats too specific.
  • Brett,
    Can you answer my curiousity.? Were you successfully able to move 4 disks from a Pro4
    to a Pro 6, and still access data?
    We don't know if both chassis were on the same f/ware.
    Thanks Marto.
  • His post says successful on the migration, apart from browser incompatibilities?
ProSupport for Business
