dendron8
Oct 11, 2015Aspirant
How to diagnose ReadyNAS
Hi all, brand new to the forum, so i apologize in advance for dumb or repeated questions. I have a ReadyNAS 102 with firmware 6.4.0. Non-RAID JBOD configuration. Each are 2TB drives one Seagate,...
Oct 24, 2015Guru - Experienced User
When the OS partition fills, the NAS will eventually become completely non-responsive. Along the way, the admin UI starts to misbehave, SMB shares then begin to misbehave, and eventually SSH stops responding. In the earlier stages, you won't see all of these.
Did you check for OS partition fullness? That is log in via ssh and then enter
df . -h
df . -i
dendron8
Nov 07, 2015Aspirant
Thanks StephenB. The output from the command looks like this:
root@helm-home-nas:~# df . -h
Filesystem Size Used Avail Use% Mounted on
/dev/md0 4.0G 3.0G 801M 79% /
root@helm-home-nas:~# df . -i
Filesystem Inodes IUsed IFree IUse% Mounted on
/dev/md0 65536 30393 35143 47% /
I am guessing that is telling me the partition is not full?
- StephenBNov 08, 2015Guru - Experienced User
root@helm-home-nas:~#I am guessing that is telling me the partition is not full?
Actually it is quite full. Normally it is around 20-30%, not 79%.
Have you moved the crashplan cache to the data volume?
