dendron8
Oct 11, 2015Aspirant
How to diagnose ReadyNAS
Hi all, brand new to the forum, so i apologize in advance for dumb or repeated questions. I have a ReadyNAS 102 with firmware 6.4.0. Non-RAID JBOD configuration. Each are 2TB drives one Seagate,...
Oct 11, 2015Guru - Experienced User
- dendron8Oct 24, 2015Aspirant
Thanks for the response StephenB. I read through some of that thread you recommended and I am not entirely convinced that is related to my problem. That thread talks about Crashplan requiring Java 1.7 or 1.8, and I already have 1.7 installed and configured:
root@helm-home-nas:~# java -version
java version "1.7.0_65"
OpenJDK Runtime Environment (IcedTea 2.5.3) (7u71-2.5.3-2~deb7u1)
OpenJDK Zero VM (build 24.65-b04, mixed mode)
root@helm-home-nas:~# cat /usr/local/crashplan/install.varsTARGETDIR=/usr/local/crashplan
BINSDIR=/usr/local/bin
MANIFESTDIR=/usr/local/var/crashplan
INITDIR=/etc/init.d
RUNLVLDIR=/etc/rc5.d
INSTALLDATE=20141219
APP_BASENAME=CrashPlan
DIR_BASENAME=crashplan
JRE_X64_DOWNLOAD_URL=http://download.code42.com/installs/proserver/jre/jre-7u45-linux-x64.tgz
JRE_I586_DOWNLOAD_URL=http://download.code42.com/installs/proserver/jre/jre-7u45-linux-i586.tgzJAVACOMMON=/usr/bin/java
root@helm-home-nas:~# which java
/usr/bin/java
root@helm-home-nas:~#Additionally, some of the posts in that thread imply that the symptom is that NONE of the shares appear. In my case, I have 2 volumes, and only 1 of them is not working. On my ReadyNAS, I see this
root@helm-home-nas:/# cd HelmVolume1
root@helm-home-nas:/HelmVolume1# ls
root@helm-home-nas:/HelmVolume1# ls -al
total 8
drwxr-xr-x 2 root root 4096 Dec 18 2014 .
drwxr-xr-x 26 root root 4096 Oct 11 09:03 ..
root@helm-home-nas:/HelmVolume1# cd ../HelmVolume2
root@helm-home-nas:/HelmVolume2# ls -al
total 8
drwxr-xr-x 1 root root 54 Dec 18 2014 .
drwxrwxrwx+ 1 guest guest 20 Dec 18 2014 HelmNAS2
drwx------ 1 root root 0 Dec 18 2014 .purge
drwxr-xr-x 1 root root 16 Dec 31 1969 ._share
drwx------ 1 root root 0 Dec 18 2014 .vault
root@helm-home-nas:/HelmVolume2#in the admin panels i see this
I am inclined to think that my HD in bay 1/HelmNAS1 is simply corrupted. Do you have any other suggestions?
- JennCOct 24, 2015NETGEAR Employee Retired
Hello dendron8,
Welcome to the community!
The NAS should still see the disk 1.
Since this is non-RAID, can you try reinserting the disk 1? If same problem, power off NAS, remove disk 1 and check it with diagnostic tools.
- StephenBOct 24, 2015Guru - Experienced User
When the OS partition fills, the NAS will eventually become completely non-responsive. Along the way, the admin UI starts to misbehave, SMB shares then begin to misbehave, and eventually SSH stops responding. In the earlier stages, you won't see all of these.
Did you check for OS partition fullness? That is log in via ssh and then enter
df . -h
df . -i
