ludovit8
Jun 30, 2013Aspirant
How to disable raid after I connect disk to computer
Hi, how can I connect my disk from raid to computer ? I have x-raid, I had there 2x1TB disk. Now I bought 2x2TB disks and I hoped that my x-raid (expandable) will just expand to 2TB :-). A unpl...
ludovit8
ok, after restart and
After changing the settings go into Frontview > System > Shutdown > Check and Fix Quotas on next boot and expansion should begin.
it expand to 2TB !!! So this problem solved and now I dont need connect old disk to computer.
(but If somebody know, how to connect disk from raid from nas to computer (sata and non raid) and see all data on that disk, he still can say :-) )
So now there left just that problem with slow copying from NAS to PC.
Btw, I forgot to tell you that if I change cable and connect nas directly to PC (so without router in the middle) all speed in both direction are very fast!!
