ludovit8
Jun 30, 2013Aspirant
How to disable raid after I connect disk to computer
Hi, how can I connect my disk from raid to computer ? I have x-raid, I had there 2x1TB disk. Now I bought 2x2TB disks and I hoped that my x-raid (expandable) will just expand to 2TB :-). A unpl...
ludovit8
Jul 01, 2013Aspirant
SORRY, FOR BOTHERING YOU.... my slow speed was due to bad cable (router - PC) so my mistake, somebody who make that cable use bad schema or just make a mistake..
I was sure that I tested new cable, but maybe I test just that one from NAS to router. My computer was working on that bad cable ok, but copying from nas via router to PC has the connection problem (slow speed).
Now, after I made new cable with right schema speed in both direction are about 24-50mbps :-) !!
