Sandshark
Apr 09, 2019Sensei
How to do incremental vertical expansion in FlexRAID mode using SSH commands
So, Netgear only lets you do vertical expansion in FlexRAID if you replace all of the drives in the volume. I'm here to tell you that, as long as you are comfortable with the command line via SSH, yo...
Retired_Member
Apr 10, 2019Hi Sandshark , thanks for posting this valuable information and kind regards.
- Sep 06, 2016Retired_Member
