Sandshark
Apr 09, 2019Sensei
How to do incremental vertical expansion in FlexRAID mode using SSH commands
So, Netgear only lets you do vertical expansion in FlexRAID if you replace all of the drives in the volume. I'm here to tell you that, as long as you are comfortable with the command line via SSH, yo...
Apr 10, 2019Guru - Experienced User
Thanks for posting. Have you tried reversing an expansion? The most common scenario here is someone adding their second disk, and expecting jbod or RAID-0 instead of RAID-1.
Sandshark wrote:
Now, this process also seems to allow you to expand a RAID6 with just two drives in a RAID1 layer or three in a RAID5.
Another option (which maintains dual redundancy) is three in RAID-1.
Sandshark wrote:
It should also allow you to expand by adding drives smaller than the largest in the system. Just create the partition(s) and add to an existing RAID group. XRAID won't let you do that.
If the partition size matchs the size of an existing RAID group that will work (and although Netgear doesn't say much about it, XRAID also will work in that case). For example, if you had 2x4TB, and later expanded it to 2x6TB then XRAID in OS 6 will actually accept a third 4 TB drive.
But if you had 2x6TB to begin with, you can'd add a 4 TB drive to that RAID group. You'd have to create a new group (on new drives).
- Sep 06, 2016Retired_Member
