Sandshark
Apr 09, 2019Sensei
How to do incremental vertical expansion in FlexRAID mode using SSH commands
So, Netgear only lets you do vertical expansion in FlexRAID if you replace all of the drives in the volume. I'm here to tell you that, as long as you are comfortable with the command line via SSH, yo...
Sandshark
Apr 11, 2019Sensei
Yes, there are some additional specifics about expansions I didn't cover. Thanks for adding that.
I started on the experiment of removng a drive and the whole thing locked up on a re-sync again. Wish I knew which drive was causing that. I'm starting over, but with a simpler system: 3x1TB RAID5 changing to 2x1TB RAID2 because I know the troublesome drive is one of the 2TB ones. From there, I can try going back to a single drive so the second can be added as RAID0 or JBOD. From what I've read, that second step is actually pretty straightforward since each drive contains all the data.
I've got the RAID sync'ed and am adding some data. So, unless it all crashes down on me again, I should have some results in a couple days.
Sandshark
Apr 12, 2019Sensei
See Reducing-RAID-size-removing-drives-WITHOUT-DATA-LOSS-is-possible for successful reduction experments.
- Sep 06, 2016Retired_Member
