fixmacs
Nov 20, 2011Guide
How-to for front USB port and backup button
I cannot find any documentation on how to program the front USB port and backup button found on the NV+. Can someone point me to the instructions? I want to backup the entire NAS to one or two externa...
fixmacs
Nov 21, 2011Guide
You should be hired by Netgear. Your tech suggestions are clear, concise and accurate. Much appreciated. I will use all the indicators you suggested including having FV send an email notice. By the way, I have the same RND4410 but with 1 GB RAM. I think it's worth the $37 I invested in the memory.
Problem solved.
Problem solved.
