pdelges
Aug 28, 2013Guide
How to format an external USB drive from OS 6.1.1 ??
I feel a bit stupid, but I couldn't find a way to format an external USB drive with my 312 under OS 6.1.1. The drive is mounted, it is even possible to access its content (it's an EXT3 drive generall...
mdgm-ntgr
Jan 14, 2014NETGEAR Employee Retired
How did you format it with NTFS? If you format it to NTFS using your Ultra does it then work if you connect it to your 316?
