pdelges
Aug 28, 2013Guide
How to format an external USB drive from OS 6.1.1 ??
I feel a bit stupid, but I couldn't find a way to format an external USB drive with my 312 under OS 6.1.1. The drive is mounted, it is even possible to access its content (it's an EXT3 drive generall...
mdgm-ntgr
Jan 15, 2014NETGEAR Employee Retired
Support should not be denied if you don't mess things up using SSH. If you enable SSH and do a
Then you can't expect support to help you. Simply doing stuff like formatting a USB disk shouldn't be an issue (provided of course you realise that formatting the USB disk wipes all the data on it).
# rm -rf /
