pdelges
Aug 28, 2013Guide
How to format an external USB drive from OS 6.1.1 ??
I feel a bit stupid, but I couldn't find a way to format an external USB drive with my 312 under OS 6.1.1. The drive is mounted, it is even possible to access its content (it's an EXT3 drive generall...
xeltros
Mar 24, 2014Apprentice
I believe that when you plug a drive, the NAS updates the configuration file and reload services. Same thing when you update user rights I think (at least via readycloud). So I believe that this is normal or at least expected since a user should never be disconnected.
My first transfer was from an USB HDD in HFS+ (I think I formatted it when I was still with snow leopard) and had no problem except those of NAS instability which have been mostly solved by updates. Never tried since then.
