ScottChapman
Oct 27, 2014Apprentice
How to format USB drive in ReadyNas Pro 2?
So, I am getting an external USB drive for doing backups. Do I need to format the drive before I connect it? Or will I be able to do that through front panel (or command line). Also, what forma...
mdgm-ntgr
Oct 28, 2014NETGEAR Employee Retired
Yes. EXT4 was added as an option in 4.2.22. You should see it as an option to format USB disks along with FAT32 and EXT3.
