f_at_lo
Jan 07, 2012Aspirant
How to increase RAID 1 volume capacity? [RESOLVED]
If have been trying to confirm the procedure on how to increase the disk capacity of a RAID 1 pair in a ReadyNAS NV+ running Radiator 4.1.8. The situation: (1) I have a ReadyNAS NV+ running Radia...
mdgm-ntgr
Jan 07, 2012NETGEAR Employee Retired
You can either backup the data on the two disks, delete the RAID-1 volume on the disks you choose to remove, then remove those disks and add two new ones, then create a new RAID-1 volume on the new disks;
or you can do the "hard way" you suggest.
Only X-RAID volumes are expandable on the NV+ v1.
