f_at_lo
Jan 07, 2012Aspirant
How to increase RAID 1 volume capacity? [RESOLVED]
If have been trying to confirm the procedure on how to increase the disk capacity of a RAID 1 pair in a ReadyNAS NV+ running Radiator 4.1.8. The situation: (1) I have a ReadyNAS NV+ running Radia...
f_at_lo
Thank you very much for your quick reply.
I don't think there there is a reason to do it the hard way for the complete setup.
As the procedure you describe needs to be performed on the "affected" disks only, it seems to be the way to go.
Olaf
P.S. (added on 9.1.2012): this still needs to be tested. If you look at viewtopic.php?f=66&t=60080, it seems not to be 100% straight forward to remove disks and to insert new ones in the same slot.
Olaf
