mito1
Jan 18, 2012Aspirant
How to keep ssh-session alive?
Hi there, i often copy a lot of large files from an USB-Share to the NAS or from the NAS to an USB Share. I use a ssh-connection and Midnight Commander because this is much faster than copy the files...
mdgm-ntgr
Jan 18, 2012NETGEAR Employee Retired
Using something like cron you can schedule a command to run in the background. I don't know if this works with mc. You can schedule a job to run and then delete the cron entry once the job is finished.
I believe you can do some midnight commander stuff as a background job. Not sure how to do this but you can search for info.
