Tennessee_Slim
Aug 29, 2011Aspirant
How to map to NAS share from Linux by CLI?
I've searched the forum and found others having problems mapping ReadyNAS shares to a *NIX box but none of that helped me find a solution.
I have two NVs, one is a plus, both are on RAIDiator 4.1.7. All shares on both NASs have CIFS and NFS only enabled and no security measures. None.
What I'm trying to do is create temporary mounts to shares on the NASs from an Ubuntu box by command line. I can do this fine using Ubuntu's "Connect to Server" applet, but that requires several user inputs, which have to be repeated every time the system is rebooted. And with several different shares to be mounted independently, it's a PITA. And I'm cultivating my Leenuks-fu again so, unfortunately, this system is requiring reboots far more frequently than any self-respecting *NIX box should. If I can figure out the CLI syntax, I can write a script but it's the syntax that has me bumfuzzled.
I'm sudo-ing the mount.cifs command and I've systematically tried what I think are all the pertinent variables to the command but I keep getting "mount error(13): Permission denied". I've used the remote host's name and it's IP address. I've tried the 'guest' option, and I've tried authenticating. I've tried user 'admin' and user 'root'. I've tried prefixing the user name with the 'domain' name and with the name of the remote host (whose login is what I'm using). I've used all the above in every possible configuration and repeated the identical procedure on both NASs. And I'm certain I'm using the proper password. 'user' and 'password' are the only options I'm trying.
Regardless of the combination, the response is:
Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
Except the man pages for mount.cifs don't give me any clue what "error(13)" is all about.
dmesg shows a long list of CIFS VFS: cifs_mount failed w/return code = -13.
The Linux box is on Ubuntu 11.04, kernel 2.6.38-11-generic. It's a headless box I administer remotely via WiFi and VNC. My network is a mixed Win32/*NIX IPV4-only workgroup, no domain or DC. My NV is the DHCP server and it is configured to use the domain name "mshome," which actually is just a workgroup.
While I had one NAS share mounted (via the appplet), I searched the entire system for any file modded within the last day that contained the name of the remote folder in that share. Linux being Linux, I figured it had to be logged in clear text somewhere, and I was hoping it would show me some snippet of syntax that might give me a "Eureka" moment. But it found nothing.
If anyone has any insight how to do this, or what I'm doing wrong, I'd be obliged if you'd pass it along.
- Tennessee_SlimAspirantI finally worked this out. No, I hadn't spent all of four years slaving over it, I'd mostly put it aside and forgotten about it. Earlier this year I'd made Linux Mint my primary desktop (couldn't live with Ubuntu's restricted superuser account), at which time it went back on the front burner.
sudo mount -t cifs -o username=<name>,password=<password>,rw,nounix,iocharset=utf8,file_mode=0777,dir_mode=0777 //192.168.100.239/<directory> /mnt/readynas
This mounts the designated directory on my NAS to the local /mnt/readynas directory.
As I mentioned earlier, there is no security on the network share. The user name and password referenced in the command are for a local account with sufficient privilege to mount a file system on the local /mnt/readynas directory.
- Aug 23, 2020Retired_Member
