saariko
Aug 15, 2011Aspirant
How to mount /readynas/home from Ubuntu?
Our 1100 is used to store all our home folders, under /home/username I am trying to mount the /home folder to an ubuntu server. However, the mount command keeps getting error 13. I have a feelin...
saariko
Aug 16, 2011Aspirant
sphardy wrote: The /home CIFS share is only available to the admin user as an administrative convenience, and therefore it is not appropriate to use that for regular user access
(note also, this share may actually be called /homes - not /home - but I cannot check this at the moment)
Rather, Home shares should be mounted as smb://nas/username using the users own login credentials
As an aside, I get the impression you are trying to access CIFS based shares in the same manner that you would typically mount NFS shares under linux - however the method does not directly translate due to different ways CIFS and NFS authenticate users and so you may wish to rethink how you do this.
Thanks for your remarks.
What I am trying to do is as follows:
- Give private access to every domain user. This is through CIFS, under the /home/USERNAME
- on top of that, I have my ubuntu server, where I have abackup job that should continusly backup ALL of the private shares. The only way I see how to do it, is to mount the /home folder (not share) and scan it for changes and backup.
- As you wrote, since the /home (or /homes) is NOT a real share, I can not really change it's CIFS/NFS settings (Can I ?)
