joja15
Jan 31, 2015Aspirant
How to read X-Raid drive on PC?
My 4 drive ReadyNas NV+ started to have sector errors on disc 3. To fix it I shutdown the unit (I know I did not need to) and replaced drive 3. Now my unit wont power up. :-( I need to access my fi...
Jan 31, 2015Guru - Experienced User
I thought that was likely given your forum join data, but it is helpful to be sure.
It is possible to access the RAID array in an x86 linux system (assuming enough USB or SATA connectors). The procedure is here: http://home.bott.ca/webserver/?p=306
If you don't have a backup, you could also try paid support at support.netgear.com
