joja15
Jan 31, 2015Aspirant
How to read X-Raid drive on PC?
My 4 drive ReadyNas NV+ started to have sector errors on disc 3. To fix it I shutdown the unit (I know I did not need to) and replaced drive 3. Now my unit wont power up. :-( I need to access my fi...
joja15
Feb 06, 2015Aspirant
StephenB wrote: I thought that was likely given your forum join data, but it is helpful to be sure.
It is possible to access the RAID array in an x86 linux system (assuming enough USB or SATA connectors). The procedure is here: http://home.bott.ca/webserver/?p=306
If you don't have a backup, you could also try paid support at support.netgear.com
I am trying to connect to the website but it seems to be done. It presents a database connection errors. Does anyone have a copy of the info of the website or a way to view an archived copy of it?
Thanks
