daiji
Dec 04, 2023Aspirant
How to remove the Readynas Pro CPUfan
Hello, I asked if it was possible to remove the HDD from a broken Readynas Ultra6 and transfer it to a new Readynas. I was unable to get a used Readynas, but finally was able to get a used Readynas...
daiji
Dec 05, 2023Aspirant
Dear Mr. Sandshark.
Thank you for your response.
I think the U-shaped plastic hook is probably the same as what Mr. Sandshark is talking about.
These are 4 plastic parts that hold the fan to the heatsink.
You are saying that I can lift the hooked part here up a little and take out the fan?
As you say, I'm worried about deterioration over time, but I'll give it a try anyway.
The double post was unintended.
My apologies.
daiji
Dear StephenB.
Thanks for the reply.
Regarding the photo, I will try to see if I can get it right.
- SandsharkDec 06, 2023Sensei
You have to pry two of the plastic hooks on the same side out just slightly, then the fan will come off. You can pry one out and lift the fan slightly on that corner, then pry out the other. I've replaced several CPU's and a couple of fans and have never broken one of the hooks. But the older they get, the more brittle the plastic likely gets. There is at least one post in the forum from somebody who did break one,
- daijiDec 06, 2023Aspirant
Hello.
I took a photo.
I intend to remove the fan with the arrowed parts at a slight angle.
If I am wrong, please let me know.- daijiDec 06, 2023Aspirant
Tell me one more thing.
I have read the past logs, but is the PIN assignment for the CPU fan connector on the ReadyNAS Pro the same as for a typical commercial fan?
In the past logs, there were posts about replacing it with a commercially available fan such as Noctua, so I assume it can be used as is, is that correct?
My ReadyNAS CPU fan is a 4PIN PWM fan connected to the motherboard.
