teo2710
May 03, 2015Aspirant
How to rename USB_HDD_2 - OS6.2.2
Hi there, Is there a way to rename my external drive volume back to USB_HDD_1. For some reason its jumped to USB_HDD_2. I am currently on OS 6.2.2. Cheers.
vandermerwe
May 04, 2015Master
I would first upgrade to 6.2.4.
If you enable ssh you can ssh in and edit the storage.conf file. This is in /etc/frontview/usb
You will need to use vi and the r command to replace the number of the USB label from 3 to 1
You can also delete any references to other USB drives.
You need to be careful that you don't make any mistakes, perhaps learn about the vi editor first.
http://www.tutorialspoint.com/unix/unix-vi-editor.htm
The USB drive reference number usually only changes if the USB drive has been removed without dismounting properly.
There may also be a problem with the USB drive compatibility that is making it do this.
Did you do anything between the change from 1 to 2 and from 2 to 3?
Editing the USB drive reference may only be a short term fix for your situation if the nas is allocating new drive references spontaneously without any incorrect dismount procedures.
