teo2710
May 03, 2015Aspirant
How to rename USB_HDD_2 - OS6.2.2
Hi there, Is there a way to rename my external drive volume back to USB_HDD_1. For some reason its jumped to USB_HDD_2. I am currently on OS 6.2.2. Cheers.
teo2710
May 04, 2015Aspirant
I definitely did not unplug or eject the ext. hdd before it jumped from 2 to 3.
Yeah I've just updated to 6.2.4.
Thank you vandermerwe for the info. I'll give it a shot with the editing.
Just something a bit off-topic but do you recommend enabling "Allow snapshot access".
On one hand its good to have rollback of files/folders in a few clicks but on the other hand
the structure of the snapshot folders lends itself to becoming infected by a ransomware easily and all your snapshots are damaged.
