teo2710
May 03, 2015Aspirant
How to rename USB_HDD_2 - OS6.2.2
Hi there, Is there a way to rename my external drive volume back to USB_HDD_1. For some reason its jumped to USB_HDD_2. I am currently on OS 6.2.2. Cheers.
vandermerwe
May 04, 2015Master
teo2710, if you decide to rename the USB reference I would dismount the USB drive first then remount it once you have renamed the reference.
You could also ask support of course, particularly if if it recurs.
