teo2710
May 03, 2015Aspirant
How to rename USB_HDD_2 - OS6.2.2
Hi there, Is there a way to rename my external drive volume back to USB_HDD_1. For some reason its jumped to USB_HDD_2. I am currently on OS 6.2.2. Cheers.
May 04, 2015Guru - Experienced User
I forget the exact path for the snapshots (and am away from my system right now).
-You can still access the snapshots with windows file explorer using admin credentials for the NAS.
-If you are using automatic snapshots, you don't want to try to using rsync to back them up, since they generally won't fit on a USB drive. If the main share is 100 GB, then each snapshot takes 100 GB on the USB drive.
