teo2710
May 03, 2015Aspirant
How to rename USB_HDD_2 - OS6.2.2
Hi there, Is there a way to rename my external drive volume back to USB_HDD_1. For some reason its jumped to USB_HDD_2. I am currently on OS 6.2.2. Cheers.
May 05, 2015Guru - Experienced User
If an older version of a file/folder is in a snapshot, then if you right click on on the current version "restore previous versions" will access the snapshot/let you restore the older file.
This feature works if either "allow snapshot access" is checked or admin credentials are stored in the windows credentials manager.
