alexofindy
Dec 05, 2011Aspirant
How to replace a disk with SMART errors
Hi, I have a readynas ultra 6 plus. The unit has a a single volume, comprised of three 3TB Western Digitial drives, model WD30EZRS, configured as a x-raid-2 single redundancy volume; these drives ...
PapaBear1
Dec 08, 2011Apprentice
Thanks for the update. Glad it is back to normal. Now you get to go through the RMA process with the old drive. Many of us tend not to use replacement drives in our NAS because they are almost always refurbished drives, and at times are drives not on the compatibility list. They do make good temp storage drives as long as you remember they have already failed once. They can also be useful as emergency drives in case of another drive failure.
