StefJar's avatar
StefJar
How to reset the network settings for my NAS duo 2000v2?
AIDAR Hey, I have problems accessing my old NAS. I can't use the browser or the explorer to access the config/drives. My configuration is: NAS --> eth --> PC Router --> WLAN --> PC The RA...
  • StephenB's avatar
    Jun 29, 2019
    StefJar wrote:
    Is there a way to reset the network config without deleting my data?
    Yes.  Do an OS reinstall - see pages 15-16 here: http://www.downloads.netgear.com/files/GDC/RND2110/Duov1_NV+v1_HW_en_06Dec11.pdf
    The NAS admin password will be changed back to netgear1 and the network configuration will be reset.  Data and other settings aren't affected.
    Then hook your NAS up to your router.  Find the IP address with RAIDar, and then browse to https://nas-ip-address/admin
ProSupport for Business
