StefJar
Jun 29, 2019Aspirant
How to reset the network settings for my NAS duo 2000v2?
AIDAR Hey, I have problems accessing my old NAS. I can't use the browser or the explorer to access the config/drives. My configuration is: NAS --> eth --> PC Router --> WLAN --> PC The RA...
- Jun 29, 2019
StefJar wrote:
Is there a way to reset the network config without deleting my data?Yes. Do an OS reinstall - see pages 15-16 here: http://www.downloads.netgear.com/files/GDC/RND2110/Duov1_NV+v1_HW_en_06Dec11.pdf
The NAS admin password will be changed back to netgear1 and the network configuration will be reset. Data and other settings aren't affected.
Then hook your NAS up to your router. Find the IP address with RAIDar, and then browse to https://nas-ip-address/admin
JohnCM_S
Jun 29, 2019NETGEAR Employee Retired
Hi StefJar,
Welcome to the Community!
Your NAS is actually a ReadyNAS Duo v1 based on its firmware.
You may try first directly connecting the PC to NAS via Ethernet then temporarily assign a static IP address of 192.168.168.100, subnet mask of 255.255.255.0, and default gateway of 192.168.168.1. You can then try accessing https://192.168.168.168/admin and see if it connects.
If you are able to access the admin page, you may change the NAS IP address to the same subnet with your router.
