StefJar
Jun 29, 2019Aspirant
How to reset the network settings for my NAS duo 2000v2?
AIDAR Hey, I have problems accessing my old NAS. I can't use the browser or the explorer to access the config/drives. My configuration is: NAS --> eth --> PC Router --> WLAN --> PC The RA...
- Jun 29, 2019
StefJar wrote:
Is there a way to reset the network config without deleting my data?Yes. Do an OS reinstall - see pages 15-16 here: http://www.downloads.netgear.com/files/GDC/RND2110/Duov1_NV+v1_HW_en_06Dec11.pdf
The NAS admin password will be changed back to netgear1 and the network configuration will be reset. Data and other settings aren't affected.
Then hook your NAS up to your router. Find the IP address with RAIDar, and then browse to https://nas-ip-address/admin
StefJar
thx for the fast response.
I set it up like StephenB mentioned. Before I didn't setup the gateway. SMP is activated as well.
Sadly it doesn't work.
If I remember I played arround with the config. So I have the feeling that I messed it up.
Jun 29, 2019Guru - Experienced User
