Bacelo
Nov 08, 2013Aspirant
How to reset USB_HDD_# UID's?
Hello, there is already a thread from 2006 with his topic but the reply on old topics is disabled. So, I ask this question again as I found no solution: How can I delete or remove USB_HDD_# UI...
mdgm-ntgr
Nov 09, 2013NETGEAR Employee Retired
Or create etc/frontview/usb in a folder on your computer and put a blank file called storage.conf in it. Zip the etc folder and then restore it via System > Config Backup in Frontview. Config backups are restored to / so if you follow the above properly it should be extracted to the correct location.
