dtarin
Sep 17, 2016Luminary
How to restore default shares?
Hi, I have a new readynas 516. I prepared a RAID 6 volume and in the process of setting that up I had to delete the original volume. My setup is working ok but I lost all the default shares. ...
- Sep 17, 2016
User folders should be recreated as each user accesses the NAS (via file explorer or finder) with their user credentials.
On default shares, therei's no automatic way to recreate them. There is nothing special about them, so you can just manually recreate the ones you use.
Sep 17, 2016Guru - Experienced User
- dtarinSep 17, 2016Luminary
Ok thanks for the info. I can live with that.
