deko220
Aug 25, 2011Aspirant
How to Rsync to external USB?
I've been using Robocopy with the /mir switch to back up Windows user data over the network to a ReadyNas Pro 6 Business. works like a charm. But now I want to backup ReadyNas data to an external US...
mdgm-ntgr
Aug 31, 2011NETGEAR Employee Retired
For backing up iSCSI targets yes you would be best to run software on the server you mount the iSCSI initiator on. It may be better to connect the USB disk to that server (if you go down the USB disk route) or if your server has an eSATA port, perhaps use that.
