jeremyotten
Jan 27, 2011Aspirant
How to setup Multipathing with XenServer and a readynas?
Hello Guys, I saw that the latest 4.2.15 firmware also support MPIO and MCS. Now I was wondering how can I enable multipathing in my xenservers to my Readynas 3200? Does anybody now the minimal ...
chirpa
Apr 12, 2011Luminary
First, I would upgrade to 4.2.16.
Not much to setting up multi-pathing on the Xen side, except providing multiple IP addresses of the NAS. Do you have the NAS teamed/bonded right now? I have a 2100 running XenServer certification tests on a constant loop. It has the two NICs standalone, and the Xen server connects to both for multipath setup.
The XenCert command executed is:
./XenCert -b lvmoiscsi -t 192.168.1.109,192.168.1.102 -q * -u /root/XenCert2.0/blockunblockiscsipaths-ntgr
********************** Welcome to XenCert 2.0 build 4 *****************
Test start time: Tue Apr 5 07:35:36 2011
Performing multipath configuration verification.
CREATING SR
Creating the SR.
PASS [Completed]
PASS [Completed]
MULTIPATH AUTOMATED PATH FAILOVER TESTING
>> Multipathd enabled for LIO-ORG, FILEIO with the following config
please confirm that these settings are optimal:
device {
path_checker directio
product GNBD
vendor GNBD
rr_weight uniform
rr_min_io 1000
bindings_file /var/lib/multipath/bindings
prio_callout none
path_grouping_policy multibus
udev_dir /dev
selector round-robin 0
getuid_callout /sbin/gnbd_import -q -U /block/%n
no_path_retry fail
polling_interval 5
user_friendly_names no
failback manual
>> Starting Random Path Block and Restore Iteration test
This test will choose a random selection of upto (n -1) paths
of a total of n to block, and verify that the IO continues
i.e. the correct paths are detected as failed, within 50 seconds.
The test then verifies that after unblocking the path, it is
restored within 2 minutes.
Path Connectivity Details
IP address HBTL Path DM status Path status
192.168.1.109 41445:0:0:0 active ready
192.168.1.102 41444:0:0:0 active ready
Create a VDI on the SR of the maximum available size.
PASS [Completed]
Create a VBD on this VDI and plug it into dom0
PASS [Completed]
Iteration 1:
-> No manual blocking of paths.
- IO test passed. Time: 0.0421931 seconds. Data: 1MB. Throughput: 24.9 MB/s
PASS [Completed]
Iteration 2:
-> Blocking 1 paths (192.168.1.109)
- Paths failover time: 2 seconds
- Maximum IO completion time: 39.1305 seconds. Data: 1MB. Throughput: 26.8 kB/s
PASS [Completed]
-> Unblocking paths, waiting for restoration.
PASS [Completed 10 seconds]
Iteration 3:
- Paths failover time: 5 seconds
- Maximum IO completion time: 0.150002 seconds. Data: 1MB. Throughput: 7.0 MB/s
PASS [Completed]
PASS [Completed 3 seconds]
Iteration 4:
-> Blocking 1 paths (192.168.1.102)
- Maximum IO completion time: 35.353 seconds. Data: 1MB. Throughput: 29.7 kB/s
PASS [Completed]
Iteration 5:
- Maximum IO completion time: 37.804 seconds. Data: 1MB. Throughput: 27.7 kB/s
PASS [Completed]
Iteration 6:
- Maximum IO completion time: 0.126137 seconds. Data: 1MB. Throughput: 8.3 MB/s
PASS [Completed]
Iteration 7:
- Paths failover time: 15 seconds
- Maximum IO completion time: 37.3044 seconds. Data: 1MB. Throughput: 28.1 kB/s
PASS [Completed]
Iteration 8:
- Maximum IO completion time: 35.84 seconds. Data: 1MB. Throughput: 29.3 kB/s
PASS [Completed]
Iteration 9:
- Maximum IO completion time: 0.114697 seconds. Data: 1MB. Throughput: 9.1 MB/s
PASS [Completed]
Iteration 10:
- Maximum IO completion time: 34.9902 seconds. Data: 1MB. Throughput: 30.0 kB/s
PASS [Completed]
Iteration 11:
- Maximum IO completion time: 0.112635 seconds. Data: 1MB. Throughput: 9.3 MB/s
PASS [Completed]
Iteration 12:
- Maximum IO completion time: 37.0907 seconds. Data: 1MB. Throughput: 28.3 kB/s
PASS [Completed]
Iteration 13:
- Maximum IO completion time: 37.2668 seconds. Data: 1MB. Throughput: 28.1 kB/s
PASS [Completed]
Iteration 14:
- Maximum IO completion time: 0.105918 seconds. Data: 1MB. Throughput: 9.9 MB/s
PASS [Completed]
Iteration 15:
- Maximum IO completion time: 0.103908 seconds. Data: 1MB. Throughput: 10.1 MB/s
PASS [Completed]
Iteration 16:
- Maximum IO completion time: 37.8332 seconds. Data: 1MB. Throughput: 27.7 kB/s
PASS [Completed]
Iteration 17:
- Maximum IO completion time: 35.2927 seconds. Data: 1MB. Throughput: 29.7 kB/s
PASS [Completed]
Iteration 18:
- Maximum IO completion time: 0.285398 seconds. Data: 1MB. Throughput: 3.7 MB/s
PASS [Completed]
Iteration 19:
- Maximum IO completion time: 35.004 seconds. Data: 1MB. Throughput: 30.0 kB/s
PASS [Completed]
Iteration 20:
- Maximum IO completion time: 0.247711 seconds. Data: 1MB. Throughput: 4.2 MB/s
PASS [Completed]
Iteration 21:
- Maximum IO completion time: 37.849 seconds. Data: 1MB. Throughput: 27.7 kB/s
PASS [Completed]
Iteration 22:
- Maximum IO completion time: 35.3155 seconds. Data: 1MB. Throughput: 29.7 kB/s
PASS [Completed]
Iteration 23:
- Maximum IO completion time: 35.4634 seconds. Data: 1MB. Throughput: 29.6 kB/s
PASS [Completed]
Iteration 24:
- Maximum IO completion time: 0.105648 seconds. Data: 1MB. Throughput: 9.9 MB/s
PASS [Completed]
Iteration 25:
- Maximum IO completion time: 0.107038 seconds. Data: 1MB. Throughput: 9.8 MB/s
PASS [Completed]
Iteration 26:
- Maximum IO completion time: 34.9806 seconds. Data: 1MB. Throughput: 30.0 kB/s
PASS [Completed]
Iteration 27:
- Maximum IO completion time: 0.121059 seconds. Data: 1MB. Throughput: 8.7 MB/s
PASS [Completed]
Iteration 28:
- Maximum IO completion time: 38.1021 seconds. Data: 1MB. Throughput: 27.5 kB/s
PASS [Completed]
Iteration 29:
- Maximum IO completion time: 0.100678 seconds. Data: 1MB. Throughput: 10.4 MB/s
PASS [Completed]
Iteration 30:
- Maximum IO completion time: 0.107484 seconds. Data: 1MB. Throughput: 9.8 MB/s
PASS [Completed]
Iteration 31:
- Maximum IO completion time: 0.114517 seconds. Data: 1MB. Throughput: 9.2 MB/s
PASS [Completed]
Iteration 32:
- Maximum IO completion time: 0.123987 seconds. Data: 1MB. Throughput: 8.5 MB/s
PASS [Completed]
PASS [Completed 4 seconds]
Iteration 33:
- Paths failover time: 4 seconds
- Maximum IO completion time: 37.7412 seconds. Data: 1MB. Throughput: 27.8 kB/s
PASS [Completed]
Iteration 34:
- Maximum IO completion time: 0.111307 seconds. Data: 1MB. Throughput: 9.4 MB/s
PASS [Completed]
Iteration 35:
- Maximum IO completion time: 0.105599 seconds. Data: 1MB. Throughput: 9.9 MB/s
PASS [Completed]
Iteration 36:
- Paths failover time: 6 seconds
- Maximum IO completion time: 36.3363 seconds. Data: 1MB. Throughput: 28.9 kB/s
PASS [Completed]
Iteration 37:
- Maximum IO completion time: 0.083428 seconds. Data: 1MB. Throughput: 12.6 MB/s
PASS [Completed]
Iteration 38:
- Paths failover time: 14 seconds
- Maximum IO completion time: 35.6491 seconds. Data: 1MB. Throughput: 29.4 kB/s
PASS [Completed]
Iteration 39:
- Paths failover time: 16 seconds
- Maximum IO completion time: 37.4629 seconds. Data: 1MB. Throughput: 28.0 kB/s
PASS [Completed]
Iteration 40:
- Maximum IO completion time: 39.0345 seconds. Data: 1MB. Throughput: 26.9 kB/s
PASS [Completed]
PASS [Completed 5 seconds]
Iteration 41:
- Maximum IO completion time: 0.109735 seconds. Data: 1MB. Throughput: 9.6 MB/s
PASS [Completed]
Iteration 42:
- Paths failover time: 11 seconds
- Maximum IO completion time: 36.6845 seconds. Data: 1MB. Throughput: 28.6 kB/s
PASS [Completed]
Iteration 43:
- Maximum IO completion time: 0.111849 seconds. Data: 1MB. Throughput: 9.4 MB/s
PASS [Completed]
Iteration 44:
- Maximum IO completion time: 0.14883 seconds. Data: 1MB. Throughput: 7.0 MB/s
PASS [Completed]
Iteration 45:
- Maximum IO completion time: 0.107017 seconds. Data: 1MB. Throughput: 9.8 MB/s
PASS [Completed]
Iteration 46:
- Paths failover time: 8 seconds
- Maximum IO completion time: 39.1248 seconds. Data: 1MB. Throughput: 26.8 kB/s
PASS [Completed]
Iteration 47:
- Paths failover time: 7 seconds
- Maximum IO completion time: 35.8069 seconds. Data: 1MB. Throughput: 29.3 kB/s
PASS [Completed]
Iteration 48:
- Paths failover time: 3 seconds
- Maximum IO completion time: 38.1541 seconds. Data: 1MB. Throughput: 27.5 kB/s
PASS [Completed]
Iteration 49:
- Maximum IO completion time: 0.198747 seconds. Data: 1MB. Throughput: 5.3 MB/s
PASS [Completed]
Iteration 50:
- Paths failover time: 17 seconds
- Maximum IO completion time: 37.3162 seconds. Data: 1MB. Throughput: 28.1 kB/s
PASS [Completed]
Iteration 51:
- Paths failover time: 13 seconds
- Maximum IO completion time: 35.7007 seconds. Data: 1MB. Throughput: 29.4 kB/s
PASS [Completed]
Iteration 52:
- Maximum IO completion time: 35.3775 seconds. Data: 1MB. Throughput: 29.6 kB/s
PASS [Completed]
Iteration 53:
- Maximum IO completion time: 35.4794 seconds. Data: 1MB. Throughput: 29.6 kB/s
PASS [Completed]
Iteration 54:
- Maximum IO completion time: 35.3853 seconds. Data: 1MB. Throughput: 29.6 kB/s
PASS [Completed]
Iteration 55:
- Maximum IO completion time: 35.432 seconds. Data: 1MB. Throughput: 29.6 kB/s
PASS [Completed]
Iteration 56:
- Maximum IO completion time: 0.109806 seconds. Data: 1MB. Throughput: 9.5 MB/s
PASS [Completed]
Iteration 57:
- Maximum IO completion time: 34.9716 seconds. Data: 1MB. Throughput: 30.0 kB/s
PASS [Completed]
Iteration 58:
- Maximum IO completion time: 38.2746 seconds. Data: 1MB. Throughput: 27.4 kB/s
PASS [Completed]
Iteration 59:
- Maximum IO completion time: 0.112776 seconds. Data: 1MB. Throughput: 9.3 MB/s
PASS [Completed]
Iteration 60:
- Maximum IO completion time: 0.11126 seconds. Data: 1MB. Throughput: 9.4 MB/s
PASS [Completed]
Iteration 61:
- Maximum IO completion time: 0.113188 seconds. Data: 1MB. Throughput: 9.3 MB/s
PASS [Completed]
Iteration 62:
- Maximum IO completion time: 0.106178 seconds. Data: 1MB. Throughput: 9.9 MB/s
PASS [Completed]
Iteration 63:
- Maximum IO completion time: 35.6341 seconds. Data: 1MB. Throughput: 29.4 kB/s
PASS [Completed]
Iteration 64:
- Maximum IO completion time: 0.108767 seconds. Data: 1MB. Throughput: 9.6 MB/s
PASS [Completed]
Iteration 65:
- Maximum IO completion time: 0.10543 seconds. Data: 1MB. Throughput: 9.9 MB/s
PASS [Completed]
Iteration 66:
- Maximum IO completion time: 0.103509 seconds. Data: 1MB. Throughput: 10.1 MB/s
PASS [Completed]
Iteration 67:
- Maximum IO completion time: 0.107273 seconds. Data: 1MB. Throughput: 9.8 MB/s
PASS [Completed]
Iteration 68:
- Maximum IO completion time: 36.0347 seconds. Data: 1MB. Throughput: 29.1 kB/s
PASS [Completed]
Iteration 69:
- Maximum IO completion time: 37.2722 seconds. Data: 1MB. Throughput: 28.1 kB/s
PASS [Completed]
Iteration 70:
- Maximum IO completion time: 0.108396 seconds. Data: 1MB. Throughput: 9.7 MB/s
PASS [Completed]
Iteration 71:
- Paths failover time: 18 seconds
- Maximum IO completion time: 38.4036 seconds. Data: 1MB. Throughput: 27.3 kB/s
PASS [Completed]
Iteration 72:
- Maximum IO completion time: 0.105931 seconds. Data: 1MB. Throughput: 9.9 MB/s
PASS [Completed]
Iteration 73:
- Maximum IO completion time: 38.9652 seconds. Data: 1MB. Throughput: 26.9 kB/s
PASS [Completed]
Iteration 74:
- Maximum IO completion time: 0.105387 seconds. Data: 1MB. Throughput: 9.9 MB/s
PASS [Completed]
Iteration 75:
- Maximum IO completion time: 38.1939 seconds. Data: 1MB. Throughput: 27.5 kB/s
PASS [Completed]
Iteration 76:
- Maximum IO completion time: 0.107252 seconds. Data: 1MB. Throughput: 9.8 MB/s
PASS [Completed]
Iteration 77:
- Maximum IO completion time: 0.107893 seconds. Data: 1MB. Throughput: 9.7 MB/s
PASS [Completed]
Iteration 78:
- Maximum IO completion time: 0.252243 seconds. Data: 1MB. Throughput: 4.2 MB/s
PASS [Completed]
Iteration 79:
- Maximum IO completion time: 0.106365 seconds. Data: 1MB. Throughput: 9.9 MB/s
PASS [Completed]
Iteration 80:
- Maximum IO completion time: 0.0610522 seconds. Data: 1MB. Throughput: 17.2 MB/s
PASS [Completed]
Iteration 81:
- Maximum IO completion time: 0.106734 seconds. Data: 1MB. Throughput: 9.8 MB/s
PASS [Completed]
Iteration 82:
- Maximum IO completion time: 38.1816 seconds. Data: 1MB. Throughput: 27.5 kB/s
PASS [Completed]
Iteration 83:
- Maximum IO completion time: 36.0624 seconds. Data: 1MB. Throughput: 29.1 kB/s
PASS [Completed]
Iteration 84:
- Paths failover time: 12 seconds
- Maximum IO completion time: 35.9937 seconds. Data: 1MB. Throughput: 29.1 kB/s
PASS [Completed]
Iteration 85:
- Maximum IO completion time: 0.111723 seconds. Data: 1MB. Throughput: 9.4 MB/s
PASS [Completed]
Iteration 86:
- Maximum IO completion time: 39.0739 seconds. Data: 1MB. Throughput: 26.8 kB/s
PASS [Completed]
Iteration 87:
- Maximum IO completion time: 39.1154 seconds. Data: 1MB. Throughput: 26.8 kB/s
PASS [Completed]
Iteration 88:
- Maximum IO completion time: 0.113624 seconds. Data: 1MB. Throughput: 9.2 MB/s
PASS [Completed]
Iteration 89:
- Maximum IO completion time: 0.152936 seconds. Data: 1MB. Throughput: 6.9 MB/s
PASS [Completed]
Iteration 90:
- Maximum IO completion time: 35.697 seconds. Data: 1MB. Throughput: 29.4 kB/s
PASS [Completed]
Iteration 91:
- Maximum IO completion time: 37.325 seconds. Data: 1MB. Throughput: 28.1 kB/s
PASS [Completed]
Iteration 92:
- Maximum IO completion time: 39.0147 seconds. Data: 1MB. Throughput: 26.9 kB/s
PASS [Completed]
Iteration 93:
- Maximum IO completion time: 37.2803 seconds. Data: 1MB. Throughput: 28.1 kB/s
PASS [Completed]
Iteration 94:
- Maximum IO completion time: 38.5571 seconds. Data: 1MB. Throughput: 27.2 kB/s
PASS [Completed]
Iteration 95:
- Maximum IO completion time: 0.106766 seconds. Data: 1MB. Throughput: 9.8 MB/s
PASS [Completed]
Iteration 96:
- Maximum IO completion time: 37.5648 seconds. Data: 1MB. Throughput: 27.9 kB/s
PASS [Completed]
Iteration 97:
- Maximum IO completion time: 0.115413 seconds. Data: 1MB. Throughput: 9.1 MB/s
PASS [Completed]
Iteration 98:
- Maximum IO completion time: 0.0803132 seconds. Data: 1MB. Throughput: 13.1 MB/s
PASS [Completed]
Iteration 99:
- Maximum IO completion time: 0.10879 seconds. Data: 1MB. Throughput: 9.6 MB/s
PASS [Completed]
- Test succeeded.
Destroy the SR.
PASS [Completed]
Performing control path stress tests.
SR CREATION, PBD PLUG-UNPLUG AND SR DELETION TESTS
>> These tests verify the control path by creating an SR, unplugging
and plugging the PBDs and destroying the SR in multiple iterations.
-> Iteration number: 0
Creating the SR.
PASS [Completed]
Unplugging and plugging PBDs over 10 iterations. Iteration number: 0..1..2..3..4..5..6..7..8..9..
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Iteration number: 1
Creating the SR.
PASS [Completed]
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Iteration number: 2
Creating the SR.
PASS [Completed]
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Iteration number: 3
Creating the SR.
PASS [Completed]
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Iteration number: 4
Creating the SR.
PASS [Completed]
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Iteration number: 5
Creating the SR.
PASS [Completed]
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Iteration number: 6
Creating the SR.
PASS [Completed]
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Iteration number: 7
Creating the SR.
PASS [Completed]
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Iteration number: 8
Creating the SR.
PASS [Completed]
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Iteration number: 9
Creating the SR.
PASS [Completed]
PASS [Completed]
Destroy the SR.
PASS [Completed]
SR SPACE AVAILABILITY TEST
>> This test verifies that all the free space advertised by an SR
is available and writable.
Create a new SR.
Creating the SR.
PASS [Completed]
PASS [Completed]
PASS [Completed]
PASS [Completed]
Now attempt to write the maximum number of bytes on this newly plugged device.
START TIME: Tue Apr 5 09:25:50 2011
APPROXIMATE RUN TIME: 2 hours, 47 minutes, 34 seconds.
END TIME: Tue Apr 5 10:05:29 2011
PASS [Completed]
Destroy the SR.
PASS [Completed]
Performing pool tests to ensure consistency.
POOL CONSISTENCY TESTS.
>> This test creates shared SRs and verifies that PBD records
display the same number of paths for each host in the pool.
-> Enabling multipathing on each host in the pool.
PASS [Completed]
-> Creating shared SR.
Creating the SR.
PASS [Completed]
-> Checking paths reflected on PBDs for each host.
Host [Active, Passive]
OpaqueRef:b19d017e-fa00-1f0f-e1cc-16a7036b5830 [2, 2]
PASS [Completed]
Destroy the SR.
PASS [Completed]
-> Disable multipathing on hosts.
Performing functional tests.
INITIALIZING SCSI DATA PATH LAYER
PASS [Completed]
DISCOVERING ADVERTISED SESSION TARGETS
IQN Session Target
iqn.2011-02.DG-LAB-ZEN-2100:zen-a 192.168.1.102:3260
iqn.2011-02.DG-LAB-ZEN-2100:zen-b 192.168.1.109:3260
iqn.2011-02.DG-LAB-ZEN-2100:zen-a 192.168.1.109:3260
iqn.2011-02.DG-LAB-ZEN-2100:zen-b 192.168.1.102:3260
PASS [Completed]
REPORT LUNS EXPOSED
>> This test logs on to all the advertised target and IQN combinations
and discovers the LUNs exposed by each including information
like the LUN ID, SCSI ID and the size of each LUN.
This test also verifies that all the sessions from the same IQN
expose the same number of LUNs and the same LUNs.
PORTAL LUN SCSI-ID Size(MiB)
192.168.1.102:3260 0 524e2d303031 40960
192.168.1.109:3260 0 524e2d303032 40960
192.168.1.109:3260 0 524e2d303031 40960
192.168.1.102:3260 0 524e2d303032 40960
PASS [Completed]
DISK IO TESTS
>> This tests execute a disk IO test against each available LUN to verify
that they are writeable and there is no apparent disk corruption.
the tests attempt to write to the LUN over each available path and
reports the number of writable paths to each LUN.
START TIME: Tue Apr 5 10:09:32 2011
APPROXIMATE RUN TIME: 2 hours, 43 minutes, 51 seconds.
- Testing LUN with SCSI ID 524e2d303032
Path num: 1. Device: /dev/sdc
PASS [Completed]
Path num: 2. Device: /dev/sde
PASS [Completed]
SCSI ID: 524e2d303032 Total paths: 2. Writable paths: 2.
PASS [Completed]
- Testing LUN with SCSI ID 524e2d303031
Path num: 1. Device: /dev/sdb
PASS [Completed]
Path num: 2. Device: /dev/sdd
PASS [Completed]
SCSI ID: 524e2d303031 Total paths: 2. Writable paths: 2.
PASS [Completed]
END TIME: Tue Apr 5 12:47:47 2011
Multipath configuration verification results : PASS, Pass percentage: 100, Completed: Tue Apr 5 08:42:32 2011
Control path stress test results : PASS, Pass percentage: 100, Completed: Tue Apr 5 10:05:58 2011
Pool test results : PASS, Pass percentage: 100, Completed: Tue Apr 5 10:07:15 2011
Functional test results : PASS, Pass percentage: 100, Completed: Tue Apr 5 12:47:49 2011
End of XenCert certification suite.
Please find the report for this test run at: /tmp/XenCert-e5ff3049-33aa-4270-a637-1497e1144573.log
Test end time: Tue Apr 5 12:47:49 2011
Execution time: 5 hours, 12 minutes, 12 seconds.
