Gaijin66
May 13, 2015Aspirant
How to show thumbnails on ACRyan PlayonHD Mini 2?
Hello everyone, I have a ReadyNAS 102 with 1 WD harddisk 2TB. This is updated to ReadyNAS OS 6.2.4. It has a wired connected to my router with a static ip. I also have an acryan playonhd mini 2 med...
TonV
May 14, 2015Aspirant
Seems more like a question for the PlayOn forum (if it still exists). I assume you access your RN102 using Samba, so all functionality regarding the display of images is up to your PlayOn...
Does it show the posters when you insert a USB stick in the PlayOn? If not then is has nothing to do with the RN102 but then it is a limitation of the PlayOn...
Sent from my SM-P900 using Tapatalk
