greymont1
Sep 30, 2014Aspirant
How to turn off continuous protection?
I have been getting alerts that x% of my ReadyNAS storage has been used, with increasing values of x. Eventually I get a message that conitnuous protect is no longer available on that volume but will ...
Sep 30, 2014Guru - Experienced User
For 6.2 its slightly different - there's a new "never" entry in the snapshot frequency pulldown. There are checkboxes for compression and bit-rot protection. Either way, you need to do it share by share.
mike-nycom wrote: if you click on the share and then click settings, there is a tick box in there for continuous protection?
Also, you need to manually delete any existing snapshots as that is not done automatically.
