Bob_Nes
Dec 12, 2014Aspirant
How to Upgrade Disks in ReadyNAS Duo V1
I have an older Sparc ReadyNas Duo V1 with RAID-X and two 500 GB Disks. We use our NAS as our primary network storage within the media share. There is the regular assortment of folders with off...
Bob_Nes
Dec 13, 2014Aspirant
How or where would I see the data on my USB drive when it is plugged into the NAS?
I see, just use the Browse... I can't access it right now because I selected "filesystem check".
Sometimes I really am a dummy...
It seems that I need to do a factory reset and I kind of like that idea anyway as it will prove that my backup strategy is working (or not).
I checked and my block size is 16384, so that's good.
I checked and my sector partition alignment is only 512, so I need the factory reset to get the 4K alignment which will be the best (or maybe even required) for my new 2TB disks.
I tried to look at my USB My Book (2TB) through Frontview where it shows:
Device Part. Description Used Size FS Speed
USB_HDD_3 1 WD My Book 1230(Partition 1) 512 MB 1862GB EXT3 480
Does that seem correct? What does that 480 speed mean?
The only option that I thought might be useful (and not destructive) was:
"filesystem check" so I clicked that.
Kind of a time consuming mistake I guess.
I think your instructions are pretty clear StephenB, so now it is just a matter of putting in the time...
Thanks again for your help.
(I especially like this approach because it seems like my worst case would be to insert the old disks).
