Bob_Nes
Dec 12, 2014Aspirant
How to Upgrade Disks in ReadyNAS Duo V1
I have an older Sparc ReadyNas Duo V1 with RAID-X and two 500 GB Disks. We use our NAS as our primary network storage within the media share. There is the regular assortment of folders with off...
vandermerwe
Dec 14, 2014Master
Have you set up users in security in Frontview?
Just set up 1 or 2 users in the security tab. Give one the name and password of your pc login credentials. If your wife has her own windows login, then do the same for her user.
Then go to the share listing and click on cifs. Thee you should be able to set read/write permissions for users or everyone. Make sure you click apply.
Once you have done this , go to the advanced tab and click the tickbox next to the paragraph about resetting permissions, then click on apply at the bottom.
Set the owner of the share as admin, and the group as users.
