Bob_Nes
Dec 12, 2014Aspirant
How to Upgrade Disks in ReadyNAS Duo V1
I have an older Sparc ReadyNas Duo V1 with RAID-X and two 500 GB Disks. We use our NAS as our primary network storage within the media share. There is the regular assortment of folders with off...
Dec 15, 2014Guru - Experienced User
It is certainly faster to back up over a gigabit connection to a PC. I suspect an Asus backup would be slower than the PC, but faster than the Duo. But you'd need to try it to be sure.
You can also use rsync to make incremental backups.
BTW, one option on the UPS test is to connect the duo to the main power, and connect something else to the APC power. Then pull the plug on the APC. When it reaches critical, the NAS should still shutdown. But it is safe either way, since the NAS never really loses power.
