MacNasMan
Aug 28, 2011Guide
How to upgrade PHP on Readynas Duo
I'm trying to setup WordPress on my Readynas, and although I'm close, I'm not able to pass this step: Step 7 – Complete WordPress installation Once you’ve saved your file, enter the following in y...
vasilik
Oct 07, 2011Aspirant
Hi,
I received the same error trying to run the install.php file ("Your server is running PHP version 5.2.0-8...)". I run the command "apt-get upgrade php5" and the frontview isn't available anymore neither the ssh connection or the website :cry: I can see the readynas duo from the raidar and the folders via the windows.
Thank you for your help!
