GJSchaller
Sep 19, 2018Guide
https://(hostname)/admin/ - Too Many Redirects
I installed a Let's Encrypt certificate using one of the other discussions on these forums. At the time, I did not set up a redirect to force HTTPS using the Apache conf, and everything worked witho...
Marc_V
Sep 26, 2018NETGEAR Employee Retired
Hi GJSchaller
You may need to manually configure it but Let's encrypt is not supported though.
Try doing an OS-reinstall.
Regards
