usncole
Apr 30, 2022Aspirant
I have a few questions regarding a RN628X storage upgrade
Hello. My NAS is currently running RAID 5 (4x8TB) and I would like to swap all of the drives with 14tb ones without data loss. Would I simply replace one drive at a time, waiting for everything to fu...
- May 01, 2022
usncole wrote:
StephenB I am wanting to expand the 8x4TB drives to 8x14TB.
Ok. Not sure if the system will let you switch to X-RAID, as it would normally use RAID-6 for 8 drives and not RAID-5.
Note that doing this one drive at a time will take quite a while, and will require a lot of disk I/O. Backing up the data, installing all the new disks at once, doing a fresh factory install, reconfiguring the NAS, and restoring the data from backup would be quite a bit quicker.
Building the array once (during the fresh install) requires 14*8 TB of disk I/O = 112 TB all together. Backup + restore adds at most 56 TB more (and that assumes your volume is completely full). So a max of 168 TB of disk I/O
One at a time with FlexRAID is about twice that - 336 TB of total disk I/O (not counting a backup for safety) That is because it resyncs the 8x4TB partitions every time you upgrade a disk, and then syncs the 8x10 TB partitions once after the final disk.
One at a time with X-RAID is even worse - 606 TB of total disk I/O (not again counting the backup for safety). That is because it supports unequal disk sizes, so it will be resyncing the 10 TB partitions multiple times.
Either way, one at a time puts a substantial load on the disks. If any of them fail during the process, you would lose all the data and would need to use data recovery. So I'd definitely recommend making the backup first.
usncole
Thanks for that info. I feel pretty stupid right now since I actually meant 8x4TB drives, but your information should still be relevant. I appreciate the assistance.
Apr 30, 2022Guru - Experienced User
Are you wanting to expand to 8x14 TB?
Or are you wanting to reduce the number of drives to four?
- StephenBMay 01, 2022Guru - Experienced User
- SandsharkMay 01, 2022Sensei
If it does let you switch to XRAID before you do any expansion, then you wouldn't have to swap out all drives at once. Just two will give you an extra 10TB, and so will each drive thereafter.
If you are comfortable with the Linux command line, you can do the same from SSH and stay in FlexRAID mode: How-to-do-incremental-vertical-expansion-in-FlexRAID-mode.
