CCChristie
Apr 24, 2021Follower
I have a similar problem as InterClaw in post [NAS not starting any services #25220444]
ReadyNas 4 Pro 4 | 4 WD Caviar-Black Drives (SATA 64 mb cache WD2001FASS) 8 spares - (1 recently flaged as failed - and replaced) 7 remain Firmware: 4.2.31 OS: Original Everything was working p...
mdgm
Apr 25, 2021Virtuoso
That looks like an old case number in the thread title.
Sounds like a full 4GB root volume or some other reason for configuration becoming corrupt.
If you have SSH already enabled and can connect it's easy to investigate using that.
Alternatively there is tech support mode (a boot menu option).
There are a number of threads describing how to troubleshoot a problem like this (well at least dealing with the full 4GB root volume part if that's the issue, not necessarily with addressing config problems).
