scheffe2804
Aug 28, 2015Aspirant
I "managed" it to completely mess up my Ready NAS Duos V2 with APT get upgrades ....
Hi all .. after that masterpice of work from me, i ask my self if there is a possibilty to completely reinstall it to get a cleas NAS again? The reset thing don´t work .. when pressing reset with th...
- Aug 28, 2015
zero (or delete the partitions on) the disks, put them into the unit and power it back up.
Both seatools and WDC's lifeguard can zero the disks. Windows disk manager (right-click computer; select manage) can delete the parititions.
Aug 28, 2015Guru - Experienced User
- scheffe2804Aug 28, 2015Aspirant
oh well .. that was easy :-)
It booted, The loaded down the Firmware, starts installing .. again reboot .. thats is :-)
Vielen Dank, thank you :-)
chris
