tmarkn
Jul 09, 2017Tutor
i updated firmware to 6.7.5 and now my iphone will not connect to readynas102
I updated the firmware to the readyNAS to 6.7.5. Access to the readyNAS from my PC is fine *it does not see the \\readynas102 path anymore but ethernet address works fine. HOWEVER, my iphone (upda...
- Jul 11, 2017
i think that i found it. I logged into the readynas. The readycloud service had gotten turned off. As soon as I re-enabled it, the service started working on both devices. Thanks for your help.
Marty_M
Jul 11, 2017NETGEAR Employee Retired
Hello tmarkn,
With the iphone are you referring to a remote(ReadyCloud) or local access? For Readycloud make the ReadyCloud user you are using to on you iphone has read/write access permission. Can you access the NAS via ReadyCoud web portal?
Marty_M
NETGEAR Community Team
- tmarknJul 11, 2017Tutor
I am accessing the readynas on my home network. I have not really tried to access it via the web. The home network was working before the firmware upgrade. It does not seem to be the read/write permissions since it recognizes the readynas but it stays offline. it would need to bring it online before read/write permissions are checked isn't it.
also, the readynas works fine from my PC. However, i now realize the my android tablet stopped working with is as well.
- Marty_MJul 12, 2017NETGEAR Employee Retired
Hello tmarkn,
We’d greatly appreciate hearing your feedback letting us know the concern has been address.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Regards,Marty_M
