tuberlook1
Nov 10, 2015Aspirant
Impending doom, how do i upgrade disk
I have a ultra 2 raidiator 4.2.26 with 2 x 2tb flex raid, two volumes ,Disk one is showing errors. Both drives are backed up to external usb drives so data is OK for now. I am going to replace the s...
Nov 10, 2015Guru - Experienced User
All you need to do is remove the bad disk (with the NAS running) and hot-insert the new one. The array should rebuild automatically.
The OS is stored on the drives, but your configuration isn't effected at all in a normal disk replacement.
tuberlook1
Sweet ! I will order the 3tb now, hopefully in before weekend, will post back and let you know how it goes.
Thanks.
- StephenBNov 10, 2015Guru - Experienced User
OOPS, just saw the 2 volume part. I was assuming flexraid/raid-1 not jbod.
That means you will lose the data volume on the failed drive and you will need to restore it from your backup.
The OS is mirrored, so you should still be able to destroy the bad volume and create a new one without losing your add-ons.
However, you should be prepared to reinstall them if something goes wrong,
- tuberlook1Nov 10, 2015Aspirant
No probs, I am more worried about the settings for SAB and sickbeard it took me ages to get them working together. is there a way to backup their respective settings and restore them ?
If you have ssh enabled, you could try to find the folders in the OS where the settings are stored, and copy them off to the data partition of the second disk.
Or try to capture screen shots of all the config information on a PC???
