Treccani
Oct 16, 2018Aspirant
Impossible cancel RN10200
On the 2 Tera Netgear RN10200 I have 97 GB of free space. I want to delete a folder of about 250 GB. After a long wait comes a window that says: "The operation can not be completed because the disk ...
- Nov 07, 2018
Dear Guru, thanks to your teachings everything has been solved. Better than the official Netgear support. Sincerely.
Oct 16, 2018Guru - Experienced User
Do you have snapshots? If so, you will need to delete the snapshots for the share the folder is in.
If that still fails, try deleting the folder from the admin web ui.
Treccani
Nov 02, 2018Aspirant
I tried to do it from the web. Seems to work because it deletes files and folders but then does not change anything in terms of space.
