Treccani
Oct 16, 2018Aspirant
Impossible cancel RN10200
On the 2 Tera Netgear RN10200 I have 97 GB of free space. I want to delete a folder of about 250 GB. After a long wait comes a window that says: "The operation can not be completed because the disk ...
- Nov 07, 2018
Dear Guru, thanks to your teachings everything has been solved. Better than the official Netgear support. Sincerely.
Treccani
Nov 02, 2018Aspirant
I tried to do it from the web. Seems to work because it deletes files and folders but then does not change anything in terms of space.
Nov 02, 2018Guru - Experienced User
Ok. Note that space is reclaimed in the background, so it might not show up right away.
Did you follow the advice about snapshots I gave above? If there are snapshots of the share, the next step is to delete them.
After that, run a balance from the volume settings wheel. That could take quite a while (days in some cases) - it depends on how fragmented the free space is.
