cwangnick
Apr 14, 2018Aspirant
Inaccurate reporting of used/free volume space?
Hi, may anybody now why the "Data" volume shows the following strange negative space and only the snapshot space is shown? FW is 6.9.3 I can access my data using win10 explorer. Dat...
- Apr 22, 2018
Try disabling quota on the volume settings wheel, not the share settings wheel. Then enable it again.
cwangnick
Apr 22, 2018Aspirant
Thanks for your feedback & hints!
I tried to set quota for the share having the questionable size. it does not work, neither for 1 Mb, 1 TB oder 20000000 TB (more than the questionable size shown for the "Backup"-Share). See picture below...
Quota worked for another share. I set a quota and than disabled it again. No change of the size of the "Backup"-Share or the whole "Data" volume.
Regards
Carsten
Apr 22, 2018Guru - Experienced User
- cwangnickMay 05, 2018Aspirant
Thank you Stephen.
disabling / enabling of quota on Volume level was the solution. Now the volume space is correctly displayed :smileyhappy:
Is this a bug if you use quota?
Sincerely
Carsten
