cwangnick
Apr 14, 2018Aspirant
Inaccurate reporting of used/free volume space?
Hi, may anybody now why the "Data" volume shows the following strange negative space and only the snapshot space is shown? FW is 6.9.3 I can access my data using win10 explorer. Dat...
- Apr 22, 2018
Try disabling quota on the volume settings wheel, not the share settings wheel. Then enable it again.
Marc_V
Apr 16, 2018NETGEAR Employee Retired
Hi cwangnick
Welcome to the Community!
Have you enable Quotas? Can you try disabling then re-enabling the feature if you have it enabled.
Also might not hurt to clean the cache of your browser and re-access the admin page.
Regards
cwangnick
May 05, 2018Aspirant
Hi Marc,
your hint with the volume rescan finally worked.
Thanks also to you!
Different Topic:
There are just small "mistakes" in the German translation:
It should say "Freier Speicher"
Furthermore it is not clear what "Geben Sie i...." should say.
In English it is "Type" and why is it not "Typ" in German?
Cheers
Carsten
